do cam gears make a big difference or not?
Old 01-27-2006, 06:58 PM
njblacksol
gangsta pancake
njblacksol's Avatar
Default do cam gears make a big difference or not?
you guys have been answering my questions lately and i apreciate it...so0o...
heres another for u guys.....do cam gears make a noticable difference????? Do i have to change my timing belt too???? what exactly happens wen u change them from stock to aftermarket?????
thanx
Old 01-27-2006, 07:26 PM
ReVenGe
ReVenGe's Avatar
well..... suposedly if you get an aftermarket cams it has higher lift which lets the valves stay open longer which makes more power..... and you dont need a new timing belt if you get one to the best of my knowledge..... cause otherwise that would suck..... but you might need to adjust the timing.... not sure... :0
Old 01-27-2006, 07:59 PM
b16ahybrid
b16ahybrid's Avatar
Cam gears allow you to adjust your intake and exhaust cam timing independently......They are useless on a stock motor, but can be benifitial on a motor that has some head work done.....I wouldn't bother with them on stock cams...You also need to tune them on a dyno.
Old 01-27-2006, 08:03 PM
bambbrose
bambbrose's Avatar
pointless on a mild motor. Worth time if you have a well built motor and a tuner who knows what they are doing
Old 01-28-2006, 08:37 AM
Sleeper Honda
Sleeper Honda's Avatar
so is upgrading the cam good on a SOHC stock D16y8?
Old 01-28-2006, 09:10 AM
NO
Old 01-28-2006, 11:17 AM
njblacksol
gangsta pancake
njblacksol's Avatar
so for his d16 changing his cams from stock to aftermarket.....it wouldn't help him and he wounldnt benifit AT ALL?????
Old 01-28-2006, 01:11 PM
bambbrose
bambbrose's Avatar
not on a stock motor, as he stated.
Stock meaning no intake manifold, port work, valvesprings, or ecu tuning.
Cams don't do shit without the proper supporting mods
Old 01-28-2006, 01:23 PM
njblacksol
gangsta pancake
njblacksol's Avatar
so if I were starting right now....to build a sohc monster.... where would i start....like wat performance parts would u buy first????
Old 01-28-2006, 02:18 PM
rampage918
rampage918's Avatar
I have a JDM B16 I/H/E and msd. I'm going to change my timing belt soon so I could just change my cam gears since its right there and set the settings to 0 and 0?
