Results 1 to 20 of 20
Thread: Blown Headgasket Sypmtoms?
  1. #1
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    How do you know if your head gasket has been damaged or blown? What do you look for?
  2. #2
    Your Powder Coater Running925's Avatar
    Join Date
    Mar 2004
    Location
    Girard, Ohio
    Posts
    4,463
    are u losing / consuming coolant?
    do u see white smoke comming from your exhaust?
    Tony Simeone
    95 Civic EX / Dart 2.0 / Dart Head / Turbo Charged 460whp 296wtq
    Daily Driver: 95 Civic DX 1.5 with 270k on the clock, still gets 41mpg on highway.
  3. #3
    Senior Member Flatland2D's Avatar
    Join Date
    Jul 2005
    Location
    Texas
    Posts
    166
    I'm wondering the same thing. Would it be possible a blown head gasket would only smoke at high rpms? My car smokes around 6k (been talking about this in my other thread) but I'm not 100% positive the smoke is "blue," because I was thinking it was oil. Come to think it of, I remember it being pretty white. I'll have to wait till daylight again to be sure. Maybe I can run outside and see if I've lost any coolant.
    I do however have to top off with oil every once in a while, so I am burning it somewhere.
    '94 Honda Del Sol
    B18C1
  4. #4
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    I have no smoke except for blueish black smoke (oil) at high rpm's. But whne I start my GSR it blows all this NASTY black soot what is it from?
  5. #5
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    but I changed it like 7 months ago, brand new OEM denso!
  6. #6
    Join Date
    Mar 2004
    Location
    Girard, Ohio
    Posts
    4,463
    Quote Originally Posted by B18C Turbo
    i get that a bout a week b4 i blow my motors!
    Tony Simeone
  7. #7
    Join Date
    Jul 2005
    Posts
    19
    welcome to my world i just spent $2300.00 getting this fixed my 2nd and 3rd cylinder where cracked and stuck. the black smoke could be a result in bad exhaust rings and my mechanic quoted me $1500 to get it fixed im leaving it for now cuz its not as bad as it was, the cracked cylinder had a huge effect on the smoke, fluids like cooilant where leaking thru and being burned get it checked out if that dosnt work then get your exhaust rings checked.
  8. #8
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Sounds like the same issues I had with my B18C before I replaced the piston rings. My money is on the rings since they are highly stressed at the high RPMs and are leaking oil into the combustion chamber. Mine also blew gunk during cold starts.
    I would suggest a compression and leakdown test to confirm but that is what I am willing to bet what the problem is.
  9. #9
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    compression test as shows
    cyl1: 205psi
    cyl2:210psi
    cyl3:200psi
    cyl4:210psi
  10. #10
    Join Date
    Mar 2004
    Location
    Girard, Ohio
    Posts
    4,463
    no bad.. numbers should be a little closer together but none the less it's got good compression.
    Tony Simeone
  11. #11
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Quote Originally Posted by Running925
    Mine had good compression when it was chugging through 3 quarts every 1000 miles. I was showing over 200 psi consistently in all cylinders. The top ring was fine but the oil control rings were shot to shit. I would do a leakdown to confirm the problem.
  12. #12
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    ya im trying to get a leak down tester cheap but nobody wants to let them go for under $40. Im all about cheap tools/parts so Im just gonna wait.
  13. #13
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Just take it in and have someone test it for you. You will most likely use that leak down tester once, so what is the difference between buying the tool and taking it in except convenience?
    I actually never got a leakdown test since I knew it was the piston rings since it had 130,000 hard miles on it and it was going through oil faster than any other problem could explain. How much oil do you burn between 3k mile oil changes?
  14. #14
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    I don't even change the oil it burns that much. Im adding so much clean oil to it I just change the filter every 3k miles. Im adding oil only when Im really getting on it. Im still getting that black soot when i do cold starts, and yeah your right, im sure my oil control rings are done @ 110k miles. The engine was boosted on before which was what did it.
  15. #15
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Sounds EXACTLY like my problem with the rings. You could waste your time/money getting a leakdown, but there is no reason. Replace those rings ASAP since that oil loss isn't good at all for the engine.
  16. #16
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    do you think that bad oil control rings and burning oil could lead to failing/fouling of the O2 sensor? Every cold start black soot comes out the exhuast, its nasty.
  17. #17
    Join Date
    Jul 2005
    Location
    Texas
    Posts
    166
    When I replaced my O2 sensor with a used but much newer one, I still have the black soot problem. Unless it fouls up the sensor really fast, I think the problem may be elsewhere.
    '94 Honda Del Sol
    B18C1
  18. #18
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Yes, it will eventually foul your O2 sensor. But what is worse is that it will kill the cat.
  19. #19
    Join Date
    Jul 2005
    Location
    Sudubry, MA
    Posts
    187
    man this is so gay. Its making such a mess of my garage floor, it looks terrible. I don't care about the cat, I actually am going to run with a 2.5" test pipe when I put the turbo kit on (thursday). I bet the cat just failed recently and now won't burn up the excess carbon/fuel/crappy black soot.
  20. #20
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Regardless of the health of the cat, this problem needs to be fixed. It is very unhealthy for the engine to be burning that much oil.
    You will need to fix the problem before you turbo. If the problem is this bad N/A, it will be aggravated a hundred times more by boost.
  21. #20
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
