Koni Yellow Question
Old 05-02-2005, 01:53 AM
Ziken
RACE USE ONLY
Ziken's Avatar
Default Koni Yellow Question
This is a question for all you people that have koni yellows. I was reading this:
The NEUSPEED/Koni shocks also feature an adjustable spring perch to level the car (5 machined grooves on the shock body for 5 positions of adjustment)
This was on a product description on a website. Is this true? Shoot if this was true, does it mean i can use just lowering springs and be able to adjust my ride height?
Old 05-02-2005, 03:52 AM
swaggs21
swaggs21's Avatar
yes this is true, there are 5 grooves on the front and 3 on the back, but you will still have to have a spring compressor everytime that you wanted to change to take the pressure off of the ring in order to compress it to move it.
I will look and see if I have pics of mine to show you what I am talking about.
:edit:
Here you go
Old 05-02-2005, 09:32 AM
chimchim
WRX cuz Honda won't wagon
chimchim's Avatar
Relative to stock, what perch placements are there on the Koni?
Old 05-02-2005, 09:35 AM
swaggs21
swaggs21's Avatar
I would say that 4-5 on the front is close to stock, and 3 on the back.
I am not sure because I never measured it, I could give you exact measure measurements tonight if you like?
Old 05-02-2005, 09:40 AM
chimchim
chimchim's Avatar
I'd appreciate it if you could.
How do you move the perch?
I'd actually want to raise my height a bit... (daily driver)
Old 05-02-2005, 09:48 AM
chimchim
chimchim's Avatar
edit
Old 05-02-2005, 11:01 AM
asiandoood
sancho on the sizzide!
asiandoood's Avatar
put it on the first groove from the top. that should raise the car by 10-20 mm.
Old 05-02-2005, 12:12 PM
swaggs21
swaggs21's Avatar
Yeah if I get some time I will jack it up and see.
With a pair of ring spreaders
