Question on motor
Old 04-25-2005, 07:16 PM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
Default Question on motor
Right now im running a 96 GSR motor with a 4-1 header, Skunk 2 mani, and a B16 tranny. when i get up around 5.5k-6k rpms i start to blow some smoke out the back. Im wondering if it was b/c the Stock P72 is adding more fuel b/c of the secondairies. I ran a compression test and it came out 200, 180, 200, 200. Could it be that i have bad rings on the 2nd cylinder? I ran a leak donw test and i ran about 20% for all 4 cylinders. Any help would be great. later down the road im planing on getting a VAFC. Will this help by tuning down the fuel on higher rpms?
Old 04-25-2005, 07:19 PM
Bricks2k4civic
Bricks2k4civic's Avatar
I think you have a minimal ammount of oil seeping into the compression chamber. How old are your seals?
Old 04-25-2005, 07:21 PM
HatchVX
HatchVX's Avatar
u mean the valve seals, I have no idea. My guess is the originals
Old 04-26-2005, 10:40 AM
Snoopy
been there done that
Snoopy's Avatar
what color is the smoke?
Old 04-26-2005, 10:48 AM
Civic2Scooby
Civic2Scooby's Avatar
do you do a wet and dry leak down test?
also what color is the smoke.
anything 180 and above is correct on the compression test according to ALLdata
edit: I ment a wet and dry compressoin test :doh:
Old 04-26-2005, 01:52 PM
HatchVX
HatchVX's Avatar
I did a dry leak down. And acording to Kai when he was driving behind me he said blue.
Old 04-26-2005, 02:02 PM
Civic2Scooby
compression seems ok...I would bet your valve stem seals are leaking. Also you should do that compression test again, then pure a cap full of oil into each cylinder and do the test again....if that low cylinder matches up with the rest, than it means the rings are going on that one cylinder.
