SOHC vtec head/cam question
Through my research on the web I have concluded that my D15z1 on my 4dr must have a performance cam. That is the only reason I can think of that d15z1 vtec would pull so much harder than my d16z6. I am guessing the cam that was installed has a much more agressive vtec lobe. So my question is. How hard would it be to swap cams in my d15z1 and d16z6? Would it be easier to just swap the whole head? Would I be loosing performance in any way? (curious If my gas mileage would go down on my d15z1 if it had a d16z6 head)
4500rpm hesitation
well, in theory, if the cam is alot more aggressive, letting more air for more duration and causing a shift in powerband, then yes, it'll most likely effect your gas mileage.
This make any sense?
Rotorphile.
D15Z1 engines don't have a "VTEC" lobe at all. At the VTEC-E crossover, the second exhaust valve is locked in to function both exhaust valves instead of just one. After the crossover, it is similar performance-wise to a DX head.
Well great. now im back to square one....
Ok, as far as I can tell the d15z1 is stock. But it jumps when it hits vtec. No other car I have been in does that @ vtec crossover. Clueless why now.
