some kind of grind when i let clutch go
Old 04-23-2005, 08:30 PM
komat
komat's Avatar
Default some kind of grind when i let clutch go
i did a jdm b16a swap into my cx
the car started up the first time
i got hte motor from hmotors
i let hte car idle for 30min b4 start driving it
oil has been change motor and tranny
so after idling for 30min
i took it for a drive
so right when i get out of my garage i hear a major grinding sound
the sound only happens when i stop and go not when i change gears(if it does happen i dont notice it since u barely hold hte clutch in while changing gears)
it grinds right when the clutch catches then once the clutch is in all the way the sound goes away
i have mix comments on what it is
the input shaft bearing and throw out bearing
also if i shift alot it wont let me go into gear unless i turn off the car and put it into gear
its sometime hard to put into gear without any force
so what do you guys think it is
