OBD-1 in an OBD-2 Civic?
Old 04-22-2005, 07:40 AM
Stalker
Stalker's Avatar
Default OBD-1 in an OBD-2 Civic?
Well I just got my car back from the shop because I had it checked for a few problems. The guy at the shop told me that some of the problems could be because I have an OBD-1 ecu in my 99 civic si. I was wondering if that would cause problems with my car. He said that it was just spliced together which I am assuming is a bad thing....
Old 04-22-2005, 07:46 AM
PDiggityDogg
Meanwhile, up in The D
PDiggityDogg's Avatar
What ecu are you using? p28 or p30? If p28, is it chipped?
Lets see a pic of the wiring...
Old 04-22-2005, 07:51 AM
swaggs21
swaggs21's Avatar
What do you have done that you need an OBD1 ecu?
The si comes with ODB2b ecu, but the obd1 would just ignore all of the obd2 stuff.
And if it was put in bad (like a bad harness) then that is possible, could cause it short out.
Old 04-22-2005, 09:39 AM
Stalker
Stalker's Avatar
Well I just bought the car and found out it had an ODB-1 in it. The guy at the shop told me it was an ODB-1 and I don't really know a whole lot about them so I don't know what kind it is or if it is chipped? Should I go ahead and replace it with an ODB-2? Would this affect the performance or anything?
Old 04-22-2005, 11:11 AM
PDiggityDogg
ECU's have a sticker on one side (bar code side) that has a slew of digits. In about the middle it will say P30, P28, P2P, etc. Find out what that code is first.
If you dont know I suggest you remove it, open it up, and take pics so we can tell you if its chipped or not. A p30 does not need to be chipped, but a p28 does.
Running the wrong program could be the source problem that youre having.
Old 04-22-2005, 12:48 PM
Stalker
Stalker's Avatar
It's a p28 ecu could post some pics if you want....
Old 04-22-2005, 01:20 PM
PDiggityDogg
I think it'd be best if you got some pics of the wiring for it and a pic of the inside, so we can see if it's been chipped or not
Old 04-22-2005, 02:46 PM
Stalker
Stalker's Avatar
PIcs....
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 04-22-2005, 02:47 PM
Stalker
Stalker's Avatar
File Type: jpg
File Type: jpg
Old 04-22-2005, 07:20 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Damn, what did he do to that harness?
Anyways, it isn't chipped.
