Results 1 to 5 of 5
Thread: Lucky 13 Strikes Again, Car Wont Move
  1. #1
    Registered User The_Reverend's Avatar
    Join Date
    Jan 2005
    Posts
    48
    The rebuild project of this 94 Honda Del Sol Has Been Quite Entertaining: Today on my way to Tokyo Speed Pros in Gilbert, I was crusing at a mere 20mph, cause my reason for going is because I needed hood pins and I had my hood tied down and didnt want to risk it flying up and breaking my windshield (again)
    Anyways, I was slowing down for a red light and POP, not a loud pop but a noticeable short noise, and my car just wouldnt go. I can shift perfectly fine, into every gear, I even get a slight grind noise if my rpm is high enough to mildly grind the reverse, however without fail, the car will not move. I noticed a vast ammount of coolant being leaked from somewhere which I have not yet determined from. However I cant see how a coolant leak could be related to this issue, and I think its just another problem I gottta fix somewhere else.
    Anyways. A friend said that possibly my axles arent pluged in right, that if either one is out then both will not operate. The car did kinda come to a mild HALT at the sound of the pop, so this makes me wonder.
    I also noticed that the car was majorly shifting left to right and was very hard to control and annoying even at low speeds, also a axle issue?
    Any ideas or sudgestions are helpful, even if your not sure, it wouldnt hurt for me to check it out anyways. Again thanks.
    The Reverend
    Please visit my project at PROJ3CT R3VR3ND
  2. #2
    Civic2Scooby's Avatar
    Join Date
    Jul 2003
    Location
    michigan
    Posts
    28,172
    Quote Originally Posted by The_Reverend
    The Reverend
    check your axles...
    SPWC Member #00001
    Quote Originally Posted by Tark
    i would eat a donkey Vagina
    Quote Originally Posted by e3NiNe
    - while you're tagging her from behind ... eat a cheeseburger. Put extra onions on it and blow into her holes.
  3. #3
    Still here... sorta... westcoaststyle's Avatar
    Join Date
    Sep 2000
    Location
    CO
    Posts
    17,177
    Quote Originally Posted by b16aEGcivic
    check your axles...
    I agree. I had this happen on a car I was working on and it wouldn't move either.
    2008 Lexus IS 350 - Starfire White
    1999 Ford Explorer 4x4 Sport
    View My Feedbacks & ADD TO THEM!!!
  4. #4
    Your Powder Coater Running925's Avatar
    Join Date
    Mar 2004
    Location
    Girard, Ohio
    Posts
    4,463
    sounds like when u put the axles in.. u just pushed them in & they never clicked into place.. sometimes u really have to put some muscle behind them.. u'll kno when they pop all the way in there!
    Tony Simeone
    95 Civic EX / Dart 2.0 / Dart Head / Turbo Charged 460whp 296wtq
    Daily Driver: 95 Civic DX 1.5 with 270k on the clock, still gets 41mpg on highway.
  5. #5
    Hybrid Forum Moderator Andy's Avatar
    Join Date
    Mar 2000
    Location
    Southwestern PA
    Posts
    2,363
    Pull the axles and I'll bet you'll find the very end piece, after the snap ring, is destroyed on one side. I don't know what engine/tranny you have but with an open LSD, all the powers getting dumped to the side that isn't connected to a wheel anymore. I was helping with a guys D16Z6 swap one time and that happened to him and I've heard of it on the forums a few times too. I don't know if you can just replace the axle and make sure it's seated or if it actually does damage to differential inside, hopefully not. Good luck with it.
  6. #5
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
