high compression
high compression
hey, i got the stock motor of a 96 civic ex and i have question on high compression pistons
what will it do for the motor? will it increase anything or decrease anything besides the compression ratio i assume.?
thanks
thanks
it's my D in a B
high compression pistons generate more power because they force combustion to occur in a smaller area in the chamber creating more forceful expansion and piston movement. They generally create power higher up in the powerband (although not always), and usually requrire altered lift and duration to create good power.
What will high compression pistons do for your stock d16y8? Odds are, not a whole lot without serious revisions elsewhere.
well im not allowed to boost the car in any way, so i was gonna do the exaust headers back new camshaft and cams, im not sure tho who has a dyno for this to tune it...
what kind of camshafts would you recommend for this? its a sohc vtec
can this be done on my own switching the pistons out?
it's my D in a B
:edit: or more pertinently, are you allowed to swap?
yes i am, but as ive stated in before posts my dad said of think about what im putting in and what i would get if i sold the car...
if i did the swap id want it in mid 2's or below and hp can be at max 160 hp... just of the motor
On permanent hiatus
Swap an LS motor in instead. Don't waste your time ripping the whole engine apart. You would need to upgrade much more than pistons and it will run you probably more than the swap with less gains. Just my $.02, though.
