d15b7 -> d16y7 direct swap?
Old 02-07-2005, 10:46 PM
White[Pony]
For relaxing times...
White[Pony]'s Avatar
Default d15b7 -> d16y7 direct swap?
I did a search and one thread was an exact match to my problem, only there were no replies :squint:
So what I need to know is, can I just drop in a d16y7 longblock in place of the d15b7 and make everything work together? plug-n-play if you will.
I know the intake/exhaust manifold, motor mounts, harness, linkage and axles will all be PnP. My main concern is the transmission and other crap. Like will the d15b7's tranny be less efficient than one that comes standard on the d16y7. If so, will it be a big enough difference to warrant spending the money to get the tranny? Also, if there are any other parts I need that aren't already in my car.
I just need to find out since no one else in my family does and I don't want to buy a d16 only to have to spend another few hundred just to get more parts to make it work. Also, this won't be modded at all, just a beater while I work and go to school and save for a better car. So performance is a nonissue.
95 civic dx, btw. pretty much all stock.
Old 02-07-2005, 10:59 PM
thomas
pew pew pew
thomas's Avatar
i think that you can just swap the head if all you want is vtec, the trannys are all the same in d-series, you will prolly need the vtec selleinods, and a ecu not really sure about that though....
Old 02-07-2005, 11:20 PM
White[Pony]
Please don't reply if you have absolutely no idea what I'm talking about
d16y7 and d15b7 have no vtec. vtec is a nonissue here.
Old 02-08-2005, 09:34 AM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
it should bolt right in. the d16y7 is an OBD2 motor so you might have some issues with the engine harness. i dont know for sure about that though. but it will definately swap right in without any problems, you should just use the DX exhaust system though since the y7 has the catalytic converter mounted on the exhaust manifold. so you should use the b7 exhaust manifold as well as the rest of the exhaust system including the cat.
Old 02-08-2005, 11:07 AM
White[Pony]
I see. I guess I'll do a search for obdI->II now Thanks for the info
Old 02-08-2005, 11:47 AM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
no prob. there is a way to convert the motor to OBD1, someone on this board would know, but not i
Old 02-08-2005, 02:20 PM
White[Pony]
From what I found on H-T it's really easy to rewire. just disconnect two wires and plug them in an "extra" connector.
Old 02-08-2005, 02:27 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
if thats what it requires then good luck! i hope it goes well. btw, why would you swap in another DX motor?
Old 02-08-2005, 02:59 PM
White[Pony]
I'd either put in another d15b7 (if the mileage was low enough) or a d16y7 (that I know has lower mileage)
My old motor is dead no matter what and I don't really care about swapping a higher HP one in. Price is pretty much the same anyway.
Old 02-08-2005, 03:04 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
oh. ok. whatever floats your boat.
