Fog Light Problem???
Today I did a DIY Yellow fogs for my 99 civic. Well I cleaned them off with alcohal then with water. I started to paint them and messed up so I took the paint off with nail polish remover then cleaned it off with water again but I kinda got a lot of water on them. Well when they were done and I hooked them back up and turned them on only one worked??? Do you think water could have got in it somehow and blown the bulb? Could there be some paint on the connector? I also rewired a sidemarker today and its on the same side that the fog light is not working, Is that just a coincedence(sp?) What would that have done? What can I do to fix it? All Info welcome.
if they are factory then the fuse should be good. They both run off the same fuse so if it blew than they would both be out. I would say its just a bulb. probably from the jaring while you had them out.
