Results 1 to 3 of 3
Thread: B16 into 93 Del Sol s need help
  1. #1
    Tired of being slow
    Join Date
    Jan 2005
    Posts
    3
    I'd like to do the swap myself but the problem is I have no idea what i'm doing. I have access to a shop with a hoist and all the tools needed to do a swap. I'm wondering if you guys could give me a hand. These are the questions i've got:
    -Which B16 should i use?
    -What additional parts do i need to buy for this swap?
    -how long should the swap take all together?
    -are there any resources on the internet that i can use?
    I'd really appreciate the help guys even if you can only answer one of the questions.
  2. #2
    NASA-VA Hyper-Announcer Solracer's Avatar
    Join Date
    Feb 2004
    Location
    Cary, NC
    Posts
    414
    I would look up Impoart Auto salavage, they sell good quality swaps, with all the parts you need.
    David Teague
    1994 Del Sol SI HS 39
    1994 Integra LS GS 39 (wifes car)
    1973 Dodge Challenger ESP 39
    Team Sol Member #24 http://www.teamdelsol.com
    My Web Site
  3. #3
    wooooo woooooooooo
    Join Date
    Mar 2002
    Location
    Twin Cities
    Posts
    3,134
    if you want to get a b16, just make sure it's obd1. That will be the cleanest and easiest way to swap it in. If you can get a complete swap from a unkyard or import engine supplier, make sure you get the complete swap with ecu, mounts, shift linkage, axles, etc. It will all bolt directly in. The only difference will be that your map sensor is on the firewall as opposed to the TB on the B series.
  4. #3
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
