Results 1 to 11 of 11
Thread: Camber Kit help
  1. #1
    Join Date
    Aug 2003
    Posts
    35
    Camber Kit help
    I have a 95 civic with tein s techs. My friend tells me I need a camber corret kit I have no idea what I need can anybody help me please.
    Do what you want to your ride, and go really really fast.
  2. #2
    Still here... sorta... westcoaststyle's Avatar
    Join Date
    Sep 2000
    Location
    CO
    Posts
    17,177
    2008 Lexus IS 350 - Starfire White
    1999 Ford Explorer 4x4 Sport
    View My Feedbacks & ADD TO THEM!!!
  3. #3
    eghatch.org bambbrose's Avatar
    Join Date
    Jan 2003
    Location
    Utah
    Posts
    1,881
    search "rear washer trick" to see a cheap and very reliable way to fix your rear camber, and then for the front you need to get decent one. I would suggest the new Omnipower front upper control arms because they are cheaper than skunk2 for the most part and are a quality peice
    1996 Civic DX coupe----SOLD
    1995 Civic DX hatch----JDM B16 ...RIP...
    1992 Civic si hatch, black, B18b1 swap, Si wheels, 50k original miles. -----SOLD-----
    1989 CRX DX, project build my little sis her first car
    1987 Suzuki Samurai----winter beater, G13k DOHC 16V MPFI swap.
    GTI powered
    New project in progress, 93 white cx, 8pt cage, k24A2 w/X2M5 trans swap. Building the perfect track car
  4. #4
    Senior Member MPerson's Avatar
    Join Date
    Jun 2003
    Location
    Eastern MA
    Posts
    4,703
    How much of a drop is the S Tech? Isn't just a ~1.8" drop? Your camber shouldn't needed to be corrected unless i'm wrong about the drop.
    ('''\(CiviC)/''')
    Red Sox Nation
    MikeyMerse
  5. #5
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Quote Originally Posted by MPerson
    With that much of a drop, a camber kit is almost necessary. I have a 2" drop and camber kits were necessary on both front and back. I have Skunk 2 in the front and Ingalls in the back.
  6. #6
    NASA-VA Hyper-Announcer Solracer's Avatar
    Join Date
    Feb 2004
    Location
    Cary, NC
    Posts
    414
    Quote Originally Posted by Shmoo
    You never know if it neccisarry before you get an aligment, most hondas their spec is .5 to -1.5 degress of camber, I have ran with -2.0 for a long time and got over 35000 miles on the set of tires I was on. Get an aligment first, then see if it is neccasiary, toe is your enemy camber is not.
    David Teague
    1994 Del Sol SI HS 39
    1994 Integra LS GS 39 (wifes car)
    1973 Dodge Challenger ESP 39
    Team Sol Member #24 http://www.teamdelsol.com
    My Web Site
  7. #7
    my bum is on the swedish! 19.3secS2K's Avatar
    Join Date
    Mar 2002
    Location
    San Antonio, Texas
    Posts
    10,133
    Quote Originally Posted by Solracer
    the alignment machine where I got mine done showed -2.0 being the absolute limit for ok camber.
    I'm down about 2.25", and used 3 washers in the rear, and they're like -1.5
    for the front, I have omni UCA's, and they're great. they're in spec
    03 s2000 (suzuka blue)
    96 civic lx (cyclone blue)
    90 accord (scratched up black)
    http://www.myspace.com/senor_flojo
  8. #8
    Join Date
    Aug 2004
    Posts
    317
    yea it all depends on each cars alignment. a friends 92 accord had a 1.5 drop and it ate tires in 5,000 miles. all the tires were bald to the point where u can see metal.
  9. #9
    Join Date
    Aug 2003
    Posts
    35
    I just paid for a new ball joint and a toe alligment. so far it seems to have almost solved the problem the guy at the shop told me that he thought that my problem was the toe from the bad ball joint. Should I even worry about a chamber kit now, my tires already need to be replaced from the horrible toe problem.
  10. #10
    Join Date
    Feb 2005
    Posts
    41
    Well, you should still get a readout of your camber to make sure you don't need a kit. I mean, just because toe was the culprit now doesn't mean camber won't be later
    Download Suspension FAQ 2.0 sections 1 and 2 here!
    94' Accord EX Coupe | JDM H22 Auto w/ LSD | Car Website (updated!!!) | My Website
    Let hypocrites be, for they are blind guides of the blind; and if one blind person guides another, both will fall into a chasm."
    -Matthew 15:14
  11. #11
    NAM #0001 TeHJuSTiN's Avatar
    Join Date
    Jun 2002
    Location
    Cornelius, NC
    Posts
    4,040
    Sometime's it's just obvious. I dropped mine around 3" all the way around and it was definitely needed.
    07 Trailblazer SS
    05 Evolution
    99 Civic
  12. #11
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
