Disc Brakes in the Rear on a 93 civic DX
Old 02-02-2005, 06:43 PM
claudio12472
claudio12472's Avatar
Default Disc Brakes in the Rear on a 93 civic DX
Just wondering if any one has a shopping list that I could use to get parts to swap out the drums for discs. I was told to find an Si at a junk yard and rip it all off but no SIs in my area. Thanks!
93 Civic DX Coupe
1.5 soon to be 1.8 GSR with a JR supercharger
Old 02-02-2005, 07:00 PM
CivicRacr
CivicRacr's Avatar
any 94+ integra rear disks will do, you'll need the rear trailing arms, brake lines, brake cable, proportioning valve and master cylinder from same integra
Old 02-02-2005, 07:01 PM
b18civic1993
b18civic1993's Avatar
u would need the master cylindar and all the proportioning valves and anything else that it has except the brake lines to make it work. if ur getting it off of a junk car i would take the front calipars to just to make sure you have a full set and save yourself problems later. those are just my suggestions though
Old 02-02-2005, 07:10 PM
CivicRacr
CivicRacr's Avatar
if he gets the front calipers, will need the front knuckles as well, as the dx ones won't work with integra front calipers
edit: of course he would need the brake lines, drum brake lines dont work with disk brake
Old 02-02-2005, 07:19 PM
b18civic1993
he dosent need integra calipers. glad you have time to sit around and try and make people feel stupid.
edit yourself: i wouldnt use any brake lines i would run new ones.
Old 02-02-2005, 07:22 PM
CivicRacr
CivicRacr's Avatar
you were saying not to get the brake lines, didnt mention anything about getting new ones, i agree getting new ones would be the way to go. but if he asked what all to get
and what do you mean he doesnt need integra calipers?
Old 02-02-2005, 08:30 PM
Outxider
X-Motoring
Outxider's Avatar
u can get the rear disc setup from the following cars because they are all the same:
94-97 del sol vtec
94-01 integra rs,ls,gs,gsr
92-95 civic si
99-00 civic si
-trailing arms(optional because your stock ones are the same)
-rear rotors
-calipers & pads
-brake lines(just get new steel braided ones)
-ebrake cables(92-95 si would be fine)
recommended but not necessary for install:
-bigger brake booster(integra rs, gsr, itr)
-master cylinder(15/16 or 1in)
-proportional valve(92-95si non abs or 94-97 integra RS)
heres a secret if you dont want to swap ur stock booster out, get a 1991 Civic EX 15/16 MC. its a direct bolt on to ur stock booster. if anything, get the prop valve, makes pedal feel better and less travel.
have fun.
Old 02-02-2005, 09:00 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
94-97 del sol vtec
92-95 civic si
99-00 civic si
-rear rotors
-calipers & pads
have fun.
Now this is the guy you need to be listening to. I would have posted that list had he not, but it wouldn't have been as difinitive. h:
Old 02-02-2005, 09:26 PM
CivicRacr
CivicRacr's Avatar
94-97 del sol vtec
92-95 civic si
99-00 civic si
-rear rotors
-calipers & pads
have fun.
good lookin out...didnt feel like explaining
Old 02-03-2005, 10:27 AM
alphaxxn
4500rpm hesitation
alphaxxn's Avatar
you *need* to get new brakelines or the brakelines from the teggy..
drum brakes do not use banjo bolts.
