cleaning headers
whats the best way to clean headers without taking them off?
JDM!
Team
SURFACE DRAGON
USAF C-17 Crewchief
You are suposed to clean them with alcohol before you install them and heat them up. What headers do you have? What type of finish?
91' Toyota Supra<--R.I.P
HEADER not
headers
87' Toyota P/U & 91' Toyota Supra<----R.I.P.
Nobody dies a virgin ... eventually life screw us all
Life consists not in holding good cards, but in playing those you hold well
USAF C-17 Crewchief
Honorary Moderator Alumni
http://www.finishfirstpolish.com
I used it on my A'PEXi GT headers and it came out like a mirror even took off some of the burned in hand prints.
Autocross is: 90% driver, 5% car, & 5%
CRAZY MOJO!
Autocross Help Page
Originally Posted by
racerdave
Hahaha...my B...I mean how do I clean my stock exhuast manifold?...and whats the best way to do it?.....I would get a header but I have no money
oh well....
JDM!
Team
SURFACE DRAGON
4500rpm hesitation
JDM_civicEG
oh well....
There is really no good ways with the stock exhaust manifold.. its just cast iron.. itll look like crap.
I got worms.
Yea, stock manifolds look like poop. The best way to clean them is by covering them up with the heatshield
99 Integra GSR
06 TSX
duck squad member #00003
Rotorphile.
A good sanding an a couple coats of high temp black paint on the stock heat sheild makes the engine look minty again.
Administrator ☂
Eagle One:
Polishing metal is no easy task. However, with these simple and effective tips, the task can be made less laborious: When polishing aluminum, speed instead of pressure is key. Apply metal polishes with a brisk motion instead of increased pressure. This will yield better results with no scratching. For removal of hard water spots from aluminum wheels, use a mixture of vinegar and water (mixed 1:1). Wipe the mixture on the surface and allow to set for 30 seconds. Wash clean and reapply until spots are gone. For routine cleaning of metal, try using 20/20 Perfect Vision Auto Glass Cleaner for a final wipe. The cleaners will produce unsurpassed shine without streaking. Dr. Wen-Chen Su, Technical Director, Eagle One, advises, "When polishing aluminum, you should see a significant amount of black appear on your rag. If you do not see this, stop. The surface is clear coated and a paint polish should be used."
USAF C-17 Crewchief
Also, any brand of silver polish kicks ass when you use it to polish aluminum wheels. Also Be carefull, some wheels have a clear coat on them...
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
