Back Coolant Flush Help
dwenrhod
I need help finding the hose where I connect the T. The heater Inlet hose #2 described in the Prestone Flushing kit. I think I know which one it is, but Im not too sure. Can someone describe the location of this hose for me? And any advice is appreciated
Steps:
-Follow the lower radiator hose (it leads to the thermostat housing)
-Locate the thermostat housing. (back passenger side of engine, under the intake manifold; pretty much right above the starter)
-there should be two approximately 3/4" heater lines that heads toward the fire wall
-follow them
-the hose with a flow control valve pretty close to the fire wall is the heater inlet hose.
take care,
ChrisS
-follow them
take care,
ChrisS
