Results 1 to 8 of 8
Thread: Striped Oil bolt
  1. #1
    Member Sonik evolved's Avatar
    Join Date
    Jan 2004
    Location
    Aurora Co
    Posts
    77
    Striped Oil bolt
    I ******g stripped the bolt that lets the oil out, it was pretty bad last time that I did my oil change but tought that it would be ok but now its really stripped, any suggestions about how to remove?
    Cleanliness is next to Godliness
  2. #2
    Join Date
    Mar 2004
    Posts
    13
    I believe you can buy bolt removers from Sears for fairly cheap. That should take care of it.
  3. #3
    something like this but you wanna make sure that it has one to fit your drain plug... I think it's a 17mm....
    http://www.sears.com/sr/javasr/produ...&vertical=TOOL
    92dx hatch......
    B16/Y21...oem lsd.....proclutch stage 3 clutch
    ACT Prolite 8lb flywheel
    Knock off header....... custom 2.25 exhaust w/cat.
    H&R race springs.......... NO DUMMY LIGHT
    My Garage <--check it out
  4. #4
    Join Date
    Jan 2004
    Location
    Aurora Co
    Posts
    77
    Thanx for suggestion much appreciated
  5. #5
    Join Date
    Mar 2004
    Posts
    13
    That is what I was talking about, thanks for the link. That should get you taken care of. Then just get a replacement and take it easy on the new one.
  6. #6
    Senior Member Wharbone's Avatar
    Join Date
    Apr 2003
    Location
    Dallas, TX
    Posts
    6,159
    replace it with a magnetic one when you get it out.
  7. #7
    X-Motoring Outxider's Avatar
    Join Date
    Nov 2000
    Location
    bay area
    Posts
    2,526
    when u put a new one back on, make sure there is that crushable washer is there too and dont super over tighten it. i usually give it one half turn after i hand tighten it.
    93 Civic Si
    www.weaksauce.org
  8. #8
    1999 Accord 4 cyl
    Join Date
    Oct 2003
    Posts
    893
    mines got stripped...took it to the mechanic..he used a chizzle
  9. #8
    Honda-Acura
    Honda S2000
    Honda-Acura
Similar Threads
  1. oil in coolant...solved
    By coco8724 in forum Engine Swaps, Tech & Tuning
    Last Post: 05-05-03, 09:59 AM
  2. Replies: 4
    Last Post: 03-19-03, 12:09 PM
  3. GS-R oil level
    By FURIOUSGSR01 in forum Integra & '97-'01 Integra Type-R
    Last Post: 02-06-03, 10:31 AM
  4. stripped oil drain pan bolt
    By agent87 in forum '92+ Civic/EL & Del Sol
    Last Post: 12-24-02, 06:54 AM
  5. will a VTEC oil pump improve oil pressure in notec engine?
    By AwwsChwA in forum Engine Swaps, Tech & Tuning
    Last Post: 09-18-02, 08:03 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
