Washer Fluid Problem
Old 01-24-2004, 03:02 PM
SiHatchR6
SiHatchR6's Avatar
Default Washer Fluid Problem
Having trouble getting my wiper fluid to work. I checked all the fuses. They are all fine. I ran an air hose through the fluid tubes to see if anything was clogging it and it was fine no clogs. When I try to turn the wiper fluid on I can hear the motor but it just wont squirt any fluid out. Any suggestions as to what I else I can check? Any help would be great thanks.
Old 01-24-2004, 05:28 PM
vassil3427
vassil3427's Avatar
Now did you try turning them on being disconnected from the squirters?
Old 01-24-2004, 05:47 PM
SUPER LAUBO
KiMBO's Hubby
SUPER LAUBO's Avatar
captain obvious says, "always check your actual tank for fluid" the pumps aren't hooked up at the bottom so if the fluid is below that point, you get no fluid!!!!
also check to see if your hose has a leak, or your squirters are clogged
:thumbup:
Old 01-24-2004, 06:11 PM
Hondaman
Black Pearl
Hondaman's Avatar
Your pump may have lost it's "prime" too. Run some fluid through the pump manualy to make sure there is liquid in the pump.
Old 06-02-2007, 06:05 PM
VTEC&MTX
VTEC&MTX's Avatar
I'm having similar issues with my washer fluid system. I checked the fuse in the set under the steering wheel - it's one fuse for the wiper blade motor and the fluid motor, and the blades work.
I used a 12v battery to power the washer fluid motor and it squirted the blue stuff with no problems.
Multimeter shows no voltage and resistance of 1 at the wiring harness that connects to motor when the system is activated. Are there any other fuses / relays i'm not aware of. Could this be the switch in the steering column, or does the wiper blade control module have anything to do with the fluid motor?
I'm not looking forward to jacking around with all the wiring and a multimeter if it comes to that...
jaje
News & Rumors Archives
31
03-14-2003 10:02 AM
HLD_Civic
92+ Civic/EL & Del Sol
11-18-2002 06:52 AM
Black2KGSR
9
09-22-2002 10:38 AM
Accord1278
Accord
3
08-09-2002 12:09 PM
dingusjt
2
07-24-2002 05:57 PM
Quick Reply: Washer Fluid Problem
