verify bushing sizes/LCAs please.
Old 01-19-2004, 10:42 AM
white_n_slow
it's my D in a B
white_n_slow's Avatar
Default verify bushing sizes/LCAs please.
I have a few poly bushings here and there, but I decided to go for the whole shebang so I'm ordering the ES full bushing kit.
I have gsr rear LCAs, and I know they have different bushing dimensions than the civic RLCAs. So I was figuring I'd just get the integra master bushing kit, since as far as I know, all the other bushings (a-arms, boots, shock bushings, etc...) are the same. The only hitch is, I have civic Si FRONT LCAs, and I'm not sure if the bushing dimensions on these are the same as the teg.
So basically, I need to know if the civic Si LCAs (swaybar compatible) are IDENTICAL to the integra ones. I know theyre interchangable, but I need to make sure the teg bushings will fit into the civic FLCA.
Any help would be greatly appreciated.
Old 01-19-2004, 11:00 AM
ManInCamo
Old School Crew
ManInCamo's Avatar
The teg kit will work on YOUR car. I have a teg ES bushing kit in my car, and I also have a teg rear LCA's and suspension etc. your Si front LCA's are the same as my EX LCA's, are the same as the teg LCAs
Old 01-19-2004, 11:02 AM
white_n_slow
it's my D in a B
Awesome, thanks. Thats what I wanted to hear
Old 01-19-2004, 02:57 PM
Andy
Hybrid Forum Moderator
Andy's Avatar
Yep, they are all interchangeable. The only thing I noticed that was different was the steering rack bushing won't work with a manual rack (the rack is physically a different diameter than a power one), everything else is interchangeable.
Old 01-19-2004, 03:01 PM
white_n_slow
it's my D in a B
I prolly wasn't gonna use the steering ones, anyway.
Old 01-19-2004, 03:08 PM
ManInCamo
Old School Crew
ManInCamo's Avatar
I didn't. Pain in the ass to get to.
Old 01-19-2004, 05:05 PM
h22avid
Sleeper...Creeper...
h22avid's Avatar
This is good stuff to know.
I ordered the Civic Master Bushing Kit and have the front end all done. I'm about to start on the rear and do my disc conversion at the same time. So will all of the bushings from my Civic kit fit the Integra rear assembly(i.e. control arms etc.)
I just ordered the bushings for the trailing arms so I'll be all bushing'd out with a new suspension here shortly.
If you're interested here's some pics of the front end suspension that I did already...
File Type: jpg
Old 01-19-2004, 05:07 PM
h22avid
h22avid's Avatar
Here's how I got most bushings in if you don't have a press...
I used a socket and a jack to press it under my tranny...shade tree style
File Type: jpg
Old 01-19-2004, 05:17 PM
h22avid
h22avid's Avatar
Sorry for the huge pics
One last thing... they forgot to include the clear silicone lubricant that is usually supplied with the kit so I called ES and the Tech there said that it would actually be better for me to use a Blue Marine Grease from the local Auto Parts store. He said it holds up much much better and is very very very water resistent.
Of course if you got the black bushings then there's not so much to worry about since they have graphite embedded in the pigment which helps to lubricate.
Old 01-19-2004, 05:25 PM
Andy
Andy's Avatar
Whatever?
File Type: jpg
