TTY learned the hard way
Old 01-07-2004, 04:48 AM
tommytoes
Driver
tommytoes's Avatar
Default TTY learned the hard way
My rebuilt b16 is almost complete. I have taken the utmost care and time to carefully do everything but last night I had a major setback.
After recieving my oil dowel and o-ring I went to install it underneath the center camshaft retainer. All went well and after checking the torque specs in my haynes (and checking them twice) I commenced to tighten the bolts to 20ft/lbs.
Thats when the shit hit the fan. I should have stopped after the first bolt wouldn't tighten but my dumbass went on to the next bolt...which snapped.....$h!t. ....and while trying to remove the first bolt it snapped too.
Upon further inspection I realized they were (had to be) Torque-To-Yield....Months of work were on the line....At 1am this morning I had finally got them both out...I had to use a chisel to cut a line in the top of what was left of the bolts (which were recessed in the holes) while not scratching the surfaces or getting metal chips in the head.....
So let everyone else learn from my mistake ...DO NOT RE-USE TTY BOLTS..... (ie..head bolts and camshaft retainer bolts)
Old 01-07-2004, 06:54 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Good lesson to learn. Sorry it happened to you man... working on your own stuff sometimes results in these kinds of things. At least now you know you'll never have that problem again.
Old 01-07-2004, 09:43 AM
Dubs
Just wait...
Dubs's Avatar
That's the best way to learn...:thumbup:
Old 01-07-2004, 10:49 AM
PDiggityDogg
Meanwhile, up in The D
PDiggityDogg's Avatar
good way to learn, agreed...shitty at the same time
good info for those who dont know...
Old 01-07-2004, 11:56 AM
tommytoes
Driver
tommytoes's Avatar
Damn that I'm tired of learning...It ain't cheap..oooh well at least it happend now and not when the motors running ....Now that would be a learning experience....
Ohh and if all goes well I should be doing the swap before February......pics will come.
Old 01-07-2004, 12:27 PM
lkailburn
college kid
lkailburn's Avatar
sorry, but i guess i don't know what TTY bolts are. could you explain?
Old 01-07-2004, 03:57 PM
Jafro
I'm made of meat!
Jafro's Avatar
He said it already. Torque To Yield. Once the bolt has been torqued to spec, it cannot be reused.
However: I re-used mine when I built my D15B7. Haven't had the first problem with leaks or anything. I torqued them 1'lb higher than spec. Don't try this at home, I'm just a cheapa$$ ba$tard. Make sure you oil the hell out of them before torqueing or you could snap them without even reaching the torque spec.
OEM bolts stretch. Most ARP's can be re-used because they don't.
Old 01-07-2004, 04:04 PM
westcoaststyle
ARP do stretch a bit as they explain in the enclosed instructions. They tell you what to torque them at based on their length... at least the ARP head studs I have.
Old 01-07-2004, 05:36 PM
Jafro
I'm made of meat!
Jafro's Avatar
But ARP's don't stretch like OEM bolts do that stretch and stay stretched. ARP's are flexible enough to return to their original shape when you take the load off of them. That's what I meant by "they don't stretch". Any bolt or stud will f#$^ up if it's over-torqued, though.
Old 01-07-2004, 07:13 PM
tommytoes
Driver
tommytoes's Avatar
sadly enough I'm guilty of this too...in my previous 89 civ dx...
no shame in being a cheap as.......is there???
