How to DIY 06+ FG2 P2R Rear Lower Tie Bar
For sean over at P2R --great cust service and extremly fast shipping
Here is the P2R Rear Lower Tie Bar now offered by Power Rev Racing...
Parts Needed:
14mm ratchet
2 jackstands
bout 20 minutes of time
I used 2 jack stands for this job. One I used to jack up one side of the car as you would to change your tire. The other i put right underneath each bolt that I was taking out on the control arm to supoort it up..
In the first pic you can see where i located the jack and began to remove the left side 14mm bolt. I suggest doing it one side at a time...
Here is a better pic of the jack holding the control arm in place. Also Now you can see the left side is installed. Make sure you dont tighten all the way and you need to move it for the other side...
Now just do the same exact thing on the other side. Jack it up and place other jack under control arm for support. Remove bolt and place P2R tie bar in place and add bolt. Tighten.
here are a few pics of this sweet a$$ part installed!!
Parts Needed:
14mm ratchet
2 jackstands
